Its a design flaw with the V8 engine. and its inevatable its going to happen at some stage and at some mileage. There are cases of engines going pop at 30k miles and some are still going at over 100k. The process of rod bearing wear through contact is sped up by not allowing the car to be warmed up before going over higher revs in general, but the flaw is the bearings will wear with this engine, and then spin destroying it.
You can get lucky of course and crack on without them being done, Only you can decide that and role the dice! I've had three V8's now, one was under BMW warranty so if it went pop, I got a new engine, one I bought with the bearings done, Nice, and the last V8 I had saw 50k miles on the engine and I could not relax until I had them done for piece of mind.
